hello all
daveellis
hello all
Unread post by daveellis »
Hi to all I'm Dave and have a major tale of woe.
My sons c3 HDi 16v wouldn't start the other day so he got relayed home from college and I got to work with my Lexia. Only fault was BSI communication fault to steering column switch so we got another module and plugged in still no joy. Old fella says check 20amp micro fuse.
This had blown changed it today and all was well erased fault.
Started her up again now have all warning lights on no fuel reading side lights stay on and ac mixer motor clicking with the keys out of the ignition any help please
x 1481
Re: hello all
Unread post by xantia_v6 »
It sounds like a BSI reset would be a good moved. If you search this site you should find instructions.
And welcome to the site.
x 5683
Re: hello all
daveellis
Re: hello all
Thank you for the reply will try it in the morni g and let you know how it goes
x 2007
Re: hello all
Unread post by Stickyfinger »
Hellloooo
As a tip, when you do it, give the battery a good charge for a few hours (go mow the lawn/have breakfast) and reconnect with a good charge in the battery.
daveellis
Re: hello all
Will do
daveellis
Re: hello all
Update
Done bsi reset and no change all warning lights still displayed.
Lexia says
Bsi cannot communicate with instruments panel
Bsi cannot communicate with air con ecu
Have checked all fuses and all are ok. Thinking now that the bsi is goosed
x 5683
Re: hello all
If it is it may be fixable.
When James (HellRazer) spots this he will supply the name and address of a guy who repairs them for a very agreeable price compared to a new one.
x 3298
Re: hello all
Erm, I have never had to have a BSi repaired. Did you mean a different James by any chance, Steve?
x 5683
Re: hello all
No, convinced it was you who had made the recommendation before James.
Wrong again :(
I blame the Alzheimers* :(
*Which the spellcheck would have as Altimeters :roll:
Anyway, I believe that BBA Reman do them but there is another highly recommended repairer, somewhere in the Leeds/Manchester area.
daveellis
Re: hello all
Gonna try bsi reset again tonight when i get off work car now starts but lots of lights on dash when doing tbe reset should i fully disconnect battery or just remove negative from it
x 2007
Re: hello all
Just the neg clamp needs removing
daveellis
Re: hello all
Dod reset and nada check fuses and all ok so i unugged black plug on bsi now there is no ignition lights no dash display nothing at all
