Grand picasso rear door glass removal
paultintin
x 6
Unread post by paultintin »
Hi can anyone with any knowledge or help tell me how to replace the glass in the rear door of a grand picasso. I have removed the door cards and trims etc but after that i have become a bit stuck. The main glass panel shouldn't be so difficult to replace but the smaller panel that's permanently in place looks riveted in place. The reason for changing the glass is because I've had to change the door(damaged) but the old door had privacy glass and new door doesn't and obviously I want it looking the same. I have thought about getting it tinted but thought this still may look odd compared to the rest of the glass on the car. I have tried to attach a photo of the glass to show what I mean. Any help would be very grateful thanks Image
Sent from my SM-G900F using Tapatalk
x 6950
Re: Grand picasso rear door glass removal
The rivets will need to be carefully drilled out to access the internals, such as the window regulator etc., and screws are used to replace it afterwards.
iingram1
Unread post by iingram1 »
could you help me with same info...im swapping rear door due to damage..c4 grand picasso 2016
