Kangoo Van
dave
x 17
Kangoo Van
Unread post by dave »
Have 61 plate Kangoo with Tomtom & Bluetooth & wind up windows !
I could do with cruise control & was wondering if any one here had retro fitted it to their vehicle ?
I'm guess steeering wheel or button from breakers & enable in renault clip ?
x 3296
Re: Kangoo Van
It does also depend on what other required equipment may be fitted. I do not know Renault vehicles, but I recently got Cruise Control running on my Citroen C5. I did need to get the relevant CC stalk and enable it in the relevant section, but there also was the need to check the brake pedal. There has to be a way to let the CC know it has been pressed (so as to disengage), and there was (in my case, at least) effectively 2 switches (OK, I had a double switch unit, as opposed to 2 distinct switches), 1 for the brake light, and the other (a 'Push to Break' type) to disengage the CC. I do NOT know how Renault would do this, or what else may be required, but give it a while, somebody with more knowledge than me will come along.
dave
x 17
Re: Kangoo Van
Hell Razor5543 wrote:get the relevant CC stalk and enable it in the relevant section, but there also was the need to check the brake pedal.....
I'm hoping it for something similar...
