Hi all
I was wondering.. How do you go about a ecu soaftware update on a c4 picasso egs ecu.. Is it easy or tricky? Where do i get the update from?
C4 Picasso software update at home
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 6950
Re: C4 Picasso software update at home
You cant with your own lexia,without a dealer account login. Citroen will do this as part of a service if you ask them, or separately for a charge.
citroenxm
- Fallen Hero
- x 70
Cant you? Oh.. I had read over on c4 picasso owners that you can..
Prehaps i should ask in there then..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 6950
On Diagbox, if you try and do an ECU download it asks for a login - fail this and it will deactivate your Diagbox. I've had this happen three times lately - so good luckcitroenxm wrote:Cant you? Oh.. I had read over on c4 picasso owners that you can.. Prehaps i should ask in there then..
Here's a similar link on C4 Owners:
http://c4owners.org/plugins/forum/forum ... 04945.post
citroenxm
- Fallen Hero
- x 70
Ok marc fair enough... You can do a self cibrate though i read by flooring it hard...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 6950
Yes - no problems with that as in a way it is a sort of 'learning' routine or an initialisation procedure that can be applied - without changing the software itself. Very much like how your car will adapt the fuel mixture according to conditions or the suspension will analyse road conditions etc. It's the actual software download to the EEPROM that needs authorisation from the PSA servers.
