paint
mikal
paint
Unread post by mikal »
I have tried and tried but darned if I can find a seller to sell me a can of spray paint.
Its a 2008 C5. paint code in the door says KGNC. After ages I think its called bourrasque blue. BUT buggered if I can find a "reasonably" priced can for sale......any ideas? :cry:
x 2941
Re: paint
The Citroen dealer is best in my opinion for spray cans, they do a pack with both the base colour and the lacquer for not much money.
x 6954
Re: paint
Halfrauds can make it up on the spot for you with the code - I had some made up a year ago when I decided to repain the internal 'rubberised' trim that has flaked off. They mix it up and transfer it to a pressurised can nowadays. They do touch up tins, aerosols, 500ml and 1 litre tins for spray guns. About £10 depending on size you want.
mikal
Re: paint
The troble with fecking Halfords is which store has paint mixing facilities, they don't tell you. ever tried filling out there contact form, they want your mothers name, you entire info from when you were born..............etc...(might have exaggerated a bit BUT u get what I mean)
So apart from them??????
x 6954
Re: paint
mikal wrote:The troble with fecking Halfords is which store has paint mixing facilities, they don't tell you. ever tried filling out there contact form, they want your mothers name, you entire info from when you were born..............etc...(might have exaggerated a bit BUT u get what I mean) So apart from them??????
No need for a form - here's the link to their store locator (I put plymouth in this one), then choose a store, click details, then at the bottom it tells you all the instore services at that branch, including paint mixing! Simples...
http://www.halfords.com/webapp/wcs/stor ... _-1_spid_1
