C5 X7 Yellow Coolant?
Lenny
x 62
Unread post by Lenny »
Evening all,
I've just realised that my coolant level is a bit low (following losing a bit when I did the EGR valve a bit back).
The stuff that is in it (probably original) is a yellow sort of colour but there's nothing in the same delicate hue in Halfords. All they could offer me was red, blue or green.
Is the genuine anti-freeze yellow?
Is it the same as anything more common (red, blue or green)?
Any advice gratefully received.
(2010 C5 2.0 HDI 160 auto)
elma
x 287
Re: C5 X7 Yellow Coolant?
Unread post by elma »
I don't think the colour gives that much away as theres not a set colour for each type, ECP have coolant for my car in at least 3 colours. It matters more that you get the right type, although I have no idea what that is for your car. If it were mine I'd either top up the coolant with DI water or replace it entirely, depending on weather it looked fresh and had good colour.
x 1751
Colour means nothing - there is no standardisation between manufacturers for coolant types and colouring.
To be safe, drain and flush the system, and refill with one type only, for both filling and subsequent topping up.
Under no circumstances should long-life OAT (organic acid) types be mixed with other varieties, because damaging inter-reaction can occur. If you are unlucky, this can take the form of precipitation, formation of goo or crystals, or system blockage. Plenty on the web about this. Have experienced it first-hand; not nice.
If adding water, only use deionised/demineralised, as advised above. This avoids the formation of limescale in the system.
old-un77
Unread post by old-un77 »
Is the collected water from a tumble dryer suitable? instead of buying Di/Dm??
just wundrin'!!!
Bob
elma
x 287
I'd use that, might want to go through a coffee filter first. My driers not a condenser so I'm yet to see the output water quality. Distilled water is basically water thats heated to steam then condensed back to water, Thats exactly what your drier gets up to.
BenC5HDi
Not Mike
x 45
Unread post by BenC5HDi »
I use RO water (reverse osmosis, pretty much all chemicals removed) from our local aquarium supplies shop. £4 for 25 litres...
Sent from my SM-N9005 using Tapatalk
old-un77
I use RO for the fish tanks, with added minerals......
tested some tumble dryer water this morning
0 nitrate
0 nitrite
< 6 gh,dt,th
0 Kh tac carbonate hardness
<6.4 Ph
0 cl (chlorine)
BenC5HDi
Not Mike
x 45
I also use RO with added minerals for the fish tanks!
x 5648
I use eau de tap for all purposes :)
BenC5HDi
Not Mike
x 45
I'd probably use it too if I lived in an area that wasn't the South East with its horrid water!
x 5648
BenC5HDi wrote:I'd probably use it too if I lived in an area that wasn't the South East with its horrid water!
There is that of course. My son and my nephew never had any success keeping fish in London.
They did try Evian water too
I run 25L of near boiling water into a demijohn, wait until it cools sufficiently then dump it in the aquarium, once a week.
Bloody fish live forever.
BenC5HDi
Not Mike
x 45
It's a nuisance keeping fish here. I almost wish I'd never started but my missus will kill me if I stop after the money I spent!
The only fish I've had success with here have been Zebra Danios, Neon and Black Widow Tetras, a ruby shark and a little bristlenose catfish. My problem is that the shark eats the neon tetras because they p**s him off by going into his hidey-hole!
Anyone want to buy 2 x 70 litre tanks, with heaters, lights and filters and some fish? :O
