Peugeot expert keep cutting out
m4rksc
Unread post by m4rksc »
Hi all. I have a fiat scudo 2.0 hdi. Psa engine as you may know. I'm having issues with it cutting out approaching junctions and such. It also does it whilst idling. I have a code which is p0230. Another fault is it continues running for a few seconds once I've switched the ignition off? The only part I've changed so far is the fuel pressure regulator on the back of the HP pump with a brand new one. Any advice would be appreciated. Thanks
jimmymarsbar
x 13
Re: Peugeot expert keep cutting out
Unread post by jimmymarsbar »
Fault code P0230 is the fuel pump primary circuit. I'm not too clever on this model, so I'm not sure if there is a fuel lift/sender pump or whether it's the fuel gauge. With a bit more info on your van (either last 8 of VIN or silhouette & engine type), I could look into it a little further for you?
x 1240
Unread post by Peter.N. »
Mmm, I was going to say change the fuel pressure regulator on the back of the HP pump - obviously not that then. Has your fuel filter been changed recently?
