C5 1.6hdi 2005 MkII - 50 amp fuse keeps on blowing ?.
Rochy101
Unread post by Rochy101 »
Hello ,
This seems to be a on going problem for me every time i jack the car up to change the tyre or brakes. Sometimes It goes just by its self on my 3rd in 1.5 months.
It is the suspension fuse every time. Any Idea's welcome. Have recently changed the thermostate sensor because the fan was continually running , that seems to have sorted that out for now. :(
Currently driving
2005 C5 Estate 1.6hdi aka "Duggy" rhd
2006 C5 Estate 1.6hdi aka "Cissy" rhd
1990 Ax 1.1 aka "Baggy" Lhd
x 1967
Re: C5 1.6hdi 2005 MkII - 50 amp fuse keeps on blowing ?.
Unread post by Stickyfinger »
I would bet a few $$'s that the main pump motor is full of dust from the brushes and is shorting out.
This thread may help
http://www.frenchcarforum.co.uk/forum/v ... 3&start=15
Rochy101
Cheers stickyfingers.
Now let me guess this is one son of a *itch job to do, I am no novice but I am not a qualified muc-a-nic . Would I need to change the bushes once taken off or a simple air line . Thanks for your help so far
Currently driving
x 1967
From my reading the pump is normally fubar'd at that point and needs changing unless you have good electrical skills.
Do a forum search for help on that as there are various methods, some of which only required the motor swapped over and use the existing control electronics so no coding to the car.
Rochy101
Changed the Hydrologic pump for suspension used a second hand jobby and bobs your uncle . job done in 4.20mins using the advise on here. top banana.
Currently driving
