Xantia clutch adjustment
tim leech
x 12
Unread post by tim leech »
Hi guys
Is the clutch cable on my 97 mk1 1.8 adjustable at all as the pedals a bit high and the clutch bite low.
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
x 8457
Re: Xantia clutch adjustment
Cable should be adjusted so the clutch pedal rubber is 6 inches above the floor Tim...
It'll be adjustable if the end of the cable at the gearbox end has an adjusting nut and locknut on the threaded end of the cable... On an auto tensioner the cable ends in a big round plate...
tim leech
x 12
Cheers jim I'll have a look, done plenty of bx ones but wasn't sure if these were self adjusting!
