Xantia s1 central locking.
Lancaster-c5
(Donor 2022)
Unread post by Lancaster-c5 »
Hi All :)
After three years of being without the central locking on my car , I have now cracked it.
This afternoon I found a site called Xantia World and on their menu they had a heading called
Check Point,which gave a list of faults on Xantias .As I started scrolling down all the usual faults I got to the last one there it said" If the Plip is working but the central locking still will not work disconnect the IR receiver and then reconnect it"but I had tried that at the start,but not with the ignition on.So I disconnected the IR in the roof switched on the ignition , switched off the ignition reconnected the IR .It resets the IR.
I then got out of the car pressed the central locking button and.......................it worked. :roll:
I had not seen this solution on any other site.
So if your Plip works and still no central locking give that a try . :)
H
C5 1.6 e-hdi
x 3296
Re: Xantia s1 central locking.
Yay! Well done. If you have a link to that site it would be useful to other Xantia owners.
Lancaster-c5
(Donor 2022)
Xantia World. http://www.kolumbus.fi › index2
Try this :)
C5 1.6 e-hdi
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Well blow me Howard.. Thats amazing! Well found.
A very sad...
1994 XM 2.1 d auto
Xantia97
Unread post by Xantia97 »
That's great Howard - will be trying that method this afternoon - I've tried every other method with no luck.
Thanks,
Juliet
1997 Xantia 1.9TD LX (owned for 14 years) - Snoopy
Gone but always remembered
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
x 1996
Unread post by Stickyfinger »
Well I cannot find index2....even with Translate: I think I am being thick today.
Xantia97
Try this - I had to put in Xantia World in Google to find it.
http://www.kolumbus.fi/perhe_pitkanen/xw/index2.htm
Juliet
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
