Xantia - Leaking front suspension cylinder ( strut )
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Just noticed today that the left front suspension cylinder ( strut ) is leaking ? Can it be repaired ?
Citroen part number is 5271E7
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 1484
Re: Xantia - Leaking front suspension cylinder ( strut )
Unread post by xantia_v6 »
Where is it leaking? And how much?
lancia58
(Donor 2022)
x 8
Hi
It is leaking where shaft enters to the strut cylinder, the strut cylinder is contaminated with fresh LHM. The other strut is clean. In both the gaiter is torn, so I can see where the shaft enters to the strut body ( cylinder ).
lancia58
(Donor 2022)
x 8
Any ideas?
x 8457
No, sadly they cannot be repaired. Replacement is the only answer I'm afraid Zohar :(
The BX struts were the last that could be disassembled and resealed...
