C5 caliper windback tool
bamba
Unread post by bamba »
I understand the c5 has right and left hand threaded calliper pistons , do i need a specific larger tool that suits the c5 ? I already have a right hand tool from machine mart for the back of my golf , but I'm thinking it may not be big enough to do the front of a c5. I can get a left hand the same size as my right for not much money from Machinemart.
x 1955
Re: C5 caliper windback tool
Unread post by Paul-R »
It's been a good few years since I last changed the pads on my old C5 but I didn't need the special tool. I was able to use a broad screwdriver from the side to carefully push against the edges of the slots and wind the pistons back in.
x 3298
My brother got me a windback tool for my birthday. I think it is safe to say that it will do most cars out there.
Citroenmad
x 110
Unread post by Citroenmad »
I have a wind back tool which has a left and a right threaded handle, which is ideal for C5s. Though I have got away with using a screwdriver and a G-clamp before I bought this.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
daviemck2006
x 485
Unread post by daviemck2006 »
I did my c5 pads with a screwdriver no problem at all.
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
x 5688
Have you a link/make for your's Chris?
Some of the kits only have the option of one wind-back direction so you need to buy additional bits for the other direction.
Citroenmad
x 110
myglaren wrote:Have you a link/make for your's Chris?
This is the set I have Steve, it does the job just nicely.
http://www.gsparkplug.com/sealey-vs0282 ... GwodiZIJHg
03 Seat Arosa 1.0S
x 3565
I've got a virtually identical kit - it's got all the same bits in it but cost a lot less than the Sealey one. I've used it on my X7 with no problems.
x 1955
Citroenmad wrote:Though I have got away with using a screwdriver and a G-clamp before I bought this.
I didn't even need the G-clamp.
I don't think I'll be rushing out to buy one of the special tools.
x 5688
Thanks Chris.
Just had new discs, pads, callipers, handbrake cables, brake pipes and exhaust done on mine :(
Cost nearly as much as I paid for the car :roll:
x 2008
Unread post by Stickyfinger »
Fill up the C5 .....5 or 6 times...... and could of bought a Xantia :)
BenC5HDi
Not Mike
x 45
Unread post by BenC5HDi »
5 or 6 times? You must have a smaller than standard tank ...
Sent from my SM-N9005 using Tapatalk
x 5688
Stickyfinger wrote:Fill up the C5 .....5 or 6 times...... and could of bought a Xantia :)
Was actually considering ragger's XM at the time.
lexi
x 133
Unread post by lexi »
If you are lucky guys, some of the collet keys for angle grinders fit various set ups.
I made mine for this C5. Cut a plate with a holesaw to correct Dia. Drilled 2 holes and put 2 pins through. Pins were made from a chuck key shaft. Weld the pins on one side to capture them and an old socket welded on to get your ratchet into. Zero cost and there is a Xantia type made as well for the slotted type.
Tools...........are the best thing for making.........tools. :)
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
