I drove a friend's 1994 1.6XL 306 and noticed how stiff his clutch pedal was. What is the most likely cause and is there an "easy fix"?
Many thanks
306 Stiff clutch pedal
solara
Nikolaymk
kevin
solara
Not too bad a job. Was slightly more diifcult on mines because of turbo getting in the way. Helps if you have a pit, or car is raised, as the trickiest bit is feeding the clutch cable through the bulkhead into the footwell.
Make sure its clipped back in all the original places. Also make sure you get the right clutch cable, as some are self adjusting (big hosed lump in middle of cable).
