The Stereo on my ZX Keeps disconnecting itself sometimes in mid journey,losing the code I am now a dab hand at putting the code in whilst driving, suggestions anyone?
Stewart
ZX Stereo
TomH
jeremy
sooty
Most likely you have a faulty connection somewhere in the 'permanent live' circuit, which maintains your code. Have a look at this link to help you find your problem, it lists the block connections.
http://www.andyspares.com/discussionfor ... IC_ID=5120
sooty
sooty
James.UK
My ZX radio (original) always comes up with "code" when first switched on, but sorts itself out in a few secs and works fine.. I once thought it was faulty, and to make things worse, I entered the wrong code [:I] I ended up havig to leave it on showing - - - for about 4 hours before it re-set and asked for code again.. Then I entered the right code and "saved". [:I] [:o)] I leave well alone now. [;)]
Russell
Hi
It sounds to me as if the power supply is being interrupted with a dodgy or intermittent connection. The radio is likely to have a permanent fused 12V feed (could be the fuse connection too). Might be worth checking where it gets it's ground (0V) connection from too, make sure it's not loose.
cheers
Russell [:)]
cheers
Russell [:)]
