Xantia Radio Upgrade
Welderone
Unread post by Welderone »
Has anyone up graded their radio in their Xantia . Peter
BenC5HDi
Not Mike
x 45
Re: Xantia Radio Upgrade
Unread post by BenC5HDi »
Yes.
Sent from my SM-N9005 using Tapatalk
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
I did too Peter.. a long time ago..
I may have the items you need, to upgrade yours..
John
Welderone
What does this involve please. Peter
BenC5HDi
Not Mike
x 45
Removing the original unit, buying the adaptor plate and wiring harness to fit a non-standard one, and the adaptor for the steering wheel controls if you want them to work. Plugging it all in and using it. It's about 20 mins of a job. .
Last time I bought one, the adaptor plate was about a fiver off eBay, the steering wheel control interface was about £13 and the wiring harness adaptor was about £8.
jgra1
(Donor 2021)
x 36
as Ben says :)
I think from memory. the choice of lead that connects the PSA car to an aftermarket stereo is dependant on the make of the stereo you want to fit.. If I still have mine they will connect Cit - Sony.. same for the wheel buttons (remote control) interface..
I doubt I have any blanky plates, but they are the cheaper bit..
I also have an interface that changes the CD stack into and auxiliary input .. not sure this would work for you but a handy feature for MP3, Dig Radio etc etc
J
chinkostu
x 30
Unread post by chinkostu »
If you want wheel controls to work you need the adaptor but they can be hit and miss, i think there were at least 2 different interfaces and neither are interchangeable!
Otherwise you only need to buy the surround to fit the radio into and a new radio. Double din won't fit so only single din. You can also get a flappy panel to cover them up like the mk2 had towards the end.
I ended up going the other way and fitting an original radio back in to use the cd changer!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
xantos
x 10
Unread post by xantos »
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
x 2008
Unread post by Stickyfinger »
xantos wrote:How about something like this...
http://www.ebay.co.uk/itm/Vintage-Car-T ... SwB4NWtyXt
Bad sound transfer via these.
I just fitted a Sony Bluetooth unit, I think the Dash in the Xantia can take a "modern" unit without it looking out of place. Even better if you get the FlipOver cover slot.
I got the unit 2nd hand on ebay for about £25.00 as there was (poilished it out) a scratch on the face, + paid £9.99 for a microphone.
Bluetooth (talks to Phone via app), USB, Jack, CD changer port etc
