Hi
I have a C4 THP make year 2009. My car is originally fitted with rear parking sensors. I want to install front parking sensors as well, but not aftermarket ones. Given I'll buy the 4 front sensors and their housing and the harness, will it function as it was originally installed i.e. the distance from the object will be displayed at the multifunction display, i.e. as the vehicle gets close to an obstacle, the sound signal becomes more rapid and the shading appears ever closer to the vehicle outline at the multifunction display
C4 THP make year 2009 - Installing front parking sensors
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
vborovic
- Locked user account
- x 40
Re: C4 THP make year 2009 - Installing front parking sensors
Probably not that simple, you most likely have a parking sensor ECU that only supports rear sensors ... you'd first need to obtain an ECU that has front & rear sensors support, and then do some telecoding with Lexia/Diagbox to enable everything related ... here's a very similar topic to read more about the procedure:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=52488
lancia58
- x 8
- x 6955
VAB - wrong link - nothing about parking on that post.
vborovic
- x 40
vborovic wrote:here's a very similar topic to read more about the procedure:
Really? I haven't mentioned the exact post, but was referring to the entire topic ...GiveMeABreak wrote:VAB - wrong link - nothing about parking on that post.
Sloppysod
- x 386
Lancia58, read the whole topic, but basically first make sure you have the correct connectors at the front and wherever the reversing ecu is, then buy the parts, fit & configure.
Using all new genuine parts will cost around £500 going on my recent experience with my C5.
Sorry for any spelling mistakes as this was sent from my mobile with predictive text turned no using Tapatalk.
Stu
