Crack off xantia anti-sink sphere - Unpressurised, Yes?
John Plum
x 5
Unread post by John Plum »
Although the rear spheres are best crack off 1/2 a turn or so whilst under pressure at high setting, I am guessing this method should not be applied to the rear antisink sphere, because the supply pipe needs to be detached first. Is that right?
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
xantos
x 10
Re: Crack off xantia anti-sink sphere - Unpressurised, Yes?
Unread post by xantos »
Yep.
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
electronmirror
x 28
Unread post by electronmirror »
Ditto.
Also, it's really worthwhile soaking the pipe going into the sphere with Plus Gas over a few days before attempting removal.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (133,509miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
John Plum
x 5
Excellent. Well, I got it off OK , and I had soaked it in plus gas for a few days (while I waited for arrival of a 3.5mm die for flare tool to tackle a supply pipe replacement). I think it made a great difference to have soaked it like that.
Then I found I'd been sent the wrong sphere! Put the old sphere back on! Huh… my fault for not checking before, sure… but gosh it's getting hard t get the right stuff supplied these days,sometimes. I've had a little run of that kind of thing. Still, she's up and running, having adapted a supply pipe with hybrid LDS and LHM unions.
John Plum
