Source for Heater panel Bulbs
x 1996
Unread post by Stickyfinger »
About to take it all apart to fix the broken bulbs, does anybody have a source for the correct bulbs in the heater panel ?
Any good guides for their replacement, I understand the unit needs to come out/taken apart. ?
x 8406
Re: Source for Heater panel Bulbs
Yes, if you can wait a couple of weeks I can let you have a couple... They are special...
x 1996
Kind of you Jim but I want to get on with the job and have a couple of spare ones on the shelf as well. If I cannot find them I may ask you to post them :)
That said it looks like a pig of a job with my big hands so may be a good thing to wait and time it for your arrival, I am sure you can just go flick flick and the heater control is apart. (? Does it need to come apart ?)
x 8406
No worries Alasdair, these are the little babies you need:
http://www.autobulbsdirect.co.uk/R509TM ... Black.html
It's not hard to swap them, just slip out the wireless, set the heater sliders roughly half-way, pop the lid off of the heater control box (now exposed after removing the wireless) and gently ease out the bulb-holder... It's like an L-shaped ladder with the two bulbs attached...
It's a bit easier with girly fingers so if you do want to wait, I'll be happy to do the job for you..
Can't post anything except on Wednesdays...
x 1996
How many do I need ?
x 8406
Stickyfinger wrote:How many do I need ?
Two sir!
x 1996
Cheers....x 4 ordered :)
x 3565
Many years ago whilst doing a similar job on one of my Xants, I think I used a small sized deep socket onto the back of the lamps to make them easier to fit. Girly hands I ain't got ! :-D
x 3296
I don't suppose anybody could tell me how to replace the cigarette lighter bulb on my MK1 C5?
x 1940
Unread post by Paul-R »
If the panel lamp bulbs are anything like the ones on the Xsara and C5 then the plastic part is just a holder. The actual bulb is a capless 286 and is cheaper. I've never bought anything other than the capless bulbs.
These are they at the same place although they do seem to be expensive. I think I paid about £4 - £5 at one of my local motor factors.
http://www.autobulbsdirect.co.uk/R286-S ... of-10.html
EDIT
These are a better price.
http://www.ebay.co.uk/itm/10-x-OSRAM-28 ... XQgoBRitmd
x 3296
On the Xantia the bulbs are captive, in a very short holder, due to the minimal space in the heater control area.
x 1940
The photo in the link doesn't look like a short bulb in the holder. Have you ever tried to pull one apart?
x 8406
Paul-R wrote:The photo in the link doesn't look like a short bulb in the holder. Have you ever tried to pull one apart?
The ones I've seen have the wire ends of the bulb welded to the black cap - unlike the instrument bulbs...
x 8406
... And therefore capless wire-ended bulbs, even if of the correct physical dimensions, cannot be used..
I know as I have tried in the past...
