Hello friends.
I bought a cheap DRL (about 2 euros as in the image) for my 406 D9, but I can not find the empty plug as I found on 406 D8.
Someone has an idea about this.?
Peugeot 406 Day time running light wiring
LOVE is All AROUND.
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1289
- Contact:
Re: Peugeot 406 Day time running light wiring
Empty plug ?...
Activa, the Moose Rider
3x C5x7 Steering racks and counting
Sorry , I mean the plug which no use. It is only the female, there is no male plug. It is only one side.Stickyfinger wrote:Empty plug ?...
LOVE is All AROUND.
- Stickyfinger
AX, little Daffodil
- Contact:
For the wires ?
What plug, what for, what do you wish to put into this plug ?
Sorry I do not understand
Sorry for unclear question,
I want to connect this DRL to my 406D9 but I have no idea how to connect it.
Someone has wiring diagram ? or an idea to wire it .
Thank you
Thank you
LOVE is All AROUND.
- xantia_v6
- Lexia Available: Yes
- My Cars: -
1997 Citroen Xantia V6 (France)
1999 Citroen XM V6 ES9 (France)
2011 Peugeot 308 CC THP 155 (NZ)
1975 Jaguar XJ-S pre-HE (NZ) - x 834
I don't know the 406 specifically, but there is probably no plug fitted for specifically fitting DRLs, as factory-fit DRLs (for Scandinavia) would have had a different headlight harness with extra relays.
How many wires do your DRLs have?
I would expect there to be a controller (either built into the DRL or separate) to disable the DRLs when the main lights are turned on.
It is only 2 wires, + and -.
I think to enable and disable during the mainlight turing on and off, I need to do an extra relay circuit.
Thank you for your idea, xantia_v6
LOVE is All AROUND.
