Urgent: help needed loan of die for 3.5mm pipe flare
John Plum
x 5
Unread post by John Plum »
I wondered if you can help with loan of 3.5mm citroen dies for flare tool: Otherwise I have a car raised on the public road, and liable to be unusable for ages, due to supplier of dies. I live in West London and can travel by public transept, OR perhaps a loan by post?
The tool is this one:
http://www.ebay.co.uk/itm/CITROEN-BRAKE ... b0RH-kyoML
Suspension pipe part number , 5270 PL, HYDRAULIC TUBE LEFT DIAM 3,5 is longer available: It has an LDS style union on the sphere end, a normal LHM union on the anti-sink valve end.
Eurocare can't help right now with their hybrid solution (out of stock).
I have a citroen flare tool, I obtained an LDS pipe for a C5 and cut the end, ready to flare
for standard LHM union.
But disaster! The 3.5 mm die for my flare tool is unusable because the two halves are different sizes although stamped 3.5mm! (it was unused since buying it - I had only used the 4.5mm) . It will take up to a month to get a replacement, because it goes via supplier to manufacturer - they don't have dies separate from kits - and the manufacturer is slow, as they depend upon batch make ups.
Cheers, John
John Plum
Xantia II Estate,1999, 2.0 HDI LX, 17000 miles, manual
x 1484
Re: Urgent: help needed loan of die for 3.5mm pipe flare
BL Autos is in that neck of the woods, they can probably flare it. Plaeides is only a bit north at Sawtry, and they definitely could!
John Plum
x 5
Thanks Richard; I'm on public transport now.
Anything closer to the A40, West London, near Ruislip? - I'm a long way from East London/Essex for BL autos.
John Plum
superloopy
x 19
Unread post by superloopy »
John ... which half of the die itself do you have/need? Surely both halves are symmetrical?? I'm not sure but that unit looks to be a Plaeides one maybe rebranded?
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
John Plum
x 5
Yes both are symmetrical. I've just spoken to Bill at Plaeides, and I'm waiting for a call back from Martin, who'll answer whether they can help with a die; i suspect they don't make them any more - maybe they'll have a spare set though… hopefully.
John Plum
John Plum
x 5
Update: Plaeides have offered to sell me a spare die set and post it out today.. what good luck!
Thanks for your kind help folk.
John
John Plum
x 2941
While you're on pipes I wonder if anyone can id this one, it's new in the bag Citroen but the part number has been obliterated from the bag.
[URL=http://s57.photobucket.com/user/fo ... .jpg[/img] [/ url]
[URL=http://s57.photobucket.com/user/fo ... .jpg[/img] [/url]
Image [/url]
x 8310
Looks to me like a late pump to regulator pipe but for what variety of hydraulic Citroen I don't know.. I'd guess a 1.8 or 2.0 petrol Xantia..
KennyW
x 164
Unread post by KennyW »
I agree Jim, the difference is the length.
C3 1.4 petrol (SWMBO)
x 2941
KennyW wrote:I agree Jim, the difference is the length.
Well if it's good for anyone on here it's free gratis, it's been moved from shelf to shelf too many times and has to go. :)
x 8310
It's useful to have just for the fittings.. A lengthening section of pipe can easily enough be brazed in to make it fit whatever car it's needed on ;)
John Plum
x 5
I braze repaired one which had twisted at the pump union, with just enough room. Had to make up in selected brass tube a joint, which I had drilled on lathe to provide the sockets for the cut ends of pipe. Works like a charm, two years on.
Is that the way you approach such joins Jim?
John Plum
x 8310
John Plum wrote:Is that the way you approach such joins Jim?
Exactly that John :D
John Plum
x 5
The News is good (this bit); 3.5mm Dies received today, adapted part flared and fitted. Chassis Suspended under Hydraulic pressure,no obvious leaks. A short road test, successful. :-). CHildren informed their scheduled outings to football practice and match , Horse riding, etc,. are on.
And thanks again for moral support.
John Plum
x 8310
Good news John :D
