Citroen Berlingo Blown Head Gasket Possible Cause?
Torqued-Nut
New User
Unread post by Torqued-Nut »
Hi i have a Citroen Berlingo 2002 1.4L petrol i purchased the car with a blown head gasket now im trying to find the problem, i have checked two of the 3 relays on the fan housing they seem to be ok and working, i have checked the temperature sensor and i get a Ohm's reading what else could their be?
Can i remove the old thermo fans and add two after market fans?
BenC5HDi
Not Mike
x 45
Re: Citroen Berlingo Blown Head Gasket Possible Cause?
Unread post by BenC5HDi »
It's a 1.4 PSA engine. They usually eventually suffer from head gasket failure. Just fix it and don't worry about it.
Sent from my SM-N9005 using Tapatalk
