Hi all,
please could one of you kind chaps tell me if there is a "piece of loom" from the seatbelt pre-tensioner electrical connector under the driver's seat, to the airbag ECU (centre console, behind gearlever, I believe) in a 2004 Berlingo Multipsace HDi?
The VIN is VF7**************[VIN obfuscated, can be read by forum staff] 93184623
I'm getting a "right hand side pre-tensioner open circuit" on Lexia. I've disconnected the pre-tensioner and stuck a 2ohm resistor on the end of the wires. This should make the airbag light go out if the pre-tensioner is faulty. Airbag light stayed on, so it must be the wiring to the airbag ECU. If a piece is available simply to replace the lot, I'd like to know before I take the seat out..
thanks!
Ben
Part info request please!
- x 6945
Re: Part info request please!
Ben - As we can't look up VIN codes on the electrical database, we have to manually select the options - I have worked out all the other stuff from the info returned on the service Docs - but still need one more piece of info. Which of the following is your vehicle:
Type 8 H1 Long Van
Long Panel Van H1 Type 12
Family Light Van
Short Van '475'
Short Van '500'
Short Van '600.
Short Van '800'
Type 8 Platform Cab?
Type 8 H1 Long Van
Family Light Van
Short Van '475'
Short Van '500'
Short Van '600.
Short Van '800'
BenC5HDi
- Not Mike
- x 45
Hell, I've no idea. I'd imagine Family Light Van. I'd think the cable from the airbag ECU to where it joins under the seat to the cable from the pretensioner would be the same on them all anyway, as it's the same airbag ECU on all of them.
Sent from my SM-N9005 using Tapatalk
- x 6945
Can you send me a PM with an email address - I've got the wiring diagrams with the harnesses shown - it looks like it's all one piece from these - but better if you check as you have the eyes on it.
- x 6945
Ben - I've got the PDFs ready for you, but calling it a night, as haven't heard from you. Let me know if you want them tomorrow.
BenC5HDi
- Not Mike
- x 45
Hello Marc, I thought I'd sent you a pm... I'll try again now, many thanks..
- x 6945
Wiring connector located - just sent part info through now Ben..,
BenC5HDi
- Not Mike
- x 45
Wonderful, many thanks for your help. Much appreciated Marc!
