Dials and Dash Lights not working
gjshucky
Unread post by gjshucky »
Evening all,
Just had a phone call from the better half. Apparently all dials in her 307 have stopped working along with their illumination. Fuel, Revs, Speed and Temp all reading zero, back light no one with headlights and no warning lights that you would expect to flash when ignition turned on.
My first thought is a fuse, but would the operation of the dials in the cluster and it's back lighting all run off the same fuse? This is the first Peugeot in the family so could be the case!
Cheers
Sent from my SM-G900F using Tapatalk
gjshucky
Re: Dials and Dash Lights not working
Was Fuse 24. Replaced and problem solved [emoji106]
