Diagbox / Lexia Software Updates - Version Changes
Handy links to other sites (car related) suggested by members
x 6945
For those members interested, I've assembled all the Citroen Diagbox change logs, detailing the patches, issues and fixes from version 6.39 (7.06) on. As there are quite a few updates, I have created a section on the Citroen section of the Forum Wiki site - here is the link:
Diagbox Change Logs
Members often ask "Do I need to upgrade my version"? Well hopefully, by looking at the version you have and scanning through the changes made on later versions, you will be able to see if there is anything in particular that affects your vehicle. As an example, I found some telecoding issues that affected my C5 X7 in Version 7.66 that were later corrected - so that warranted me upgrading, as my central locking plip options had disappeared from the central display after using a prior version!
Just be aware:- before making a decision about upgrading your Diagbox version, make sure your hardware interface will support any firmware upgrade that may be needed to use the later versions of the software. If an update requires a newer firmware version, it will attempt to upgrade the hardware, so if your interface is too old, it may not work and could end up bricking your hardware :cry: :-({|=
There is a solution to prevent the automatic upgrading of the firmware (thanks to Andy for cobbing together the procedure), but please be aware that some newer updates to Diagbox may not fully work without the VCI (Vehicle Communications Interface) having the required firmware update. It will, however, save your interface from being 'bricked' if you know you have an earlier interface (i.e. Revision 'B'), and want to try a newer version of the software without the risk!
To tell Diagbox to not update the firmware in the interface:
First ensure that Diagbox is shut down completely then open c:\ awroot \ bin \ launcher \ ap.ini
Near the top of that file find:
CODE: SELECT ALL
MAJ_COM=TRUE
Change to:
CODE: SELECT ALL
MAJ_COM=FALSE
Save the file.
A reboot is strongly recommended to allow the changes to be take effect before you re-use Diagbox.
Reverse this procedure if you have replaced your Hardware interface with a 'full chip' Revision 'C' Interface to allow Diagbox to apply any relevant firmware updates.
cancunia
Re: Diagbox / Lexia Software Updates - Version Changes
Unread post by cancunia »
Many thanks for making the Change Log, and the advice about about preventing upgrades to the hardware interface. They helped me understand which version of Diagbox was the earliest that would work with my B9 Partner (7.11) due to issues with the EDC17C10_BR2 ECU as used on B9 Partners & Berlingos with earlier Diagbox versions. I had to use an early version due to the Rev B hardware interface that I have.
x 6945
You're welcome - thanks for looking, it makes it worthwhile in the end. :)
Gin31
Unread post by Gin31 »
I would just like to say thank you to Givemeabreak for listing the update versions of the Diagbox software.
Lexia is difficult to install for a lot of people, but now knowing there is not much point going beyond Version 7-20 for my old Citroens is good news.
I wonder if many other people are banging their heads for no reason.
x 6945
IF you are having specific issues, have a look in the diagnostics section - and post a new query there if you need some help.
Diagnostics Section
Hagrid
x 3
Unread post by Hagrid »
Thanks Marc for yet more useful info!
