Citroen Synergie 2.0 hdi 2001 engine light on
shahidocean
x 6
Unread post by shahidocean »
Guys the engine warning light came on today. I drove it around it has power and acceleration and seems perfectly ok.
I'm a couple of hundred miles away from home visiting family. I need to drive back tommorow before I can get it checked
any ideas. I have been hearing a humming/whining noise very quite runs for about 5 minutes after the cars stops, and if i accelerate hard in cold weather I get a little white smoke I wonder if these are related. Should I call the aa for a tow ?
x 1240
Re: Citroen Synergie 2.0 hdi 2001 engine light on
Unread post by Peter.N. »
There are any number of reasons for the light to come on, if it drives OK and there are no obvious faults like overheating or low oil pressure I wouldn't worry about it.
ken newbold
x 4
Unread post by ken newbold »
I dunno what the cause is, but I had one the same, it ran ok and I remember hearing the noise you describe. But it didn't seem to bother it at all.
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
shahidocean
x 6
heah good news guys the light just went out by itself so its fixed ! I filled up with fuel from the opposite side of the pump and it overflowed I put the cap and then drove about 200 miles.
The light came on the following day. Before I left for the return journey I opened the cap briefly and shortly after the light just went out. Could that have caused it ? The car is all fine runs like a rocket.
