C5 injector pipe torque setting
ricasso
Unread post by ricasso »
2002 C5 HDI 2.2 I'm looking for the correct torque setting for the pipe that goes from the high pressure pump to the fuel rail, (the small U shaped metal pipe) many thanks!
x 1240
Re: C5 injector pipe torque setting
Unread post by Peter.N. »
Doesn't specify the 2.2 engine in the Haynes book but the 2.0. 16 valve is 25Nm or 18lbs/ft. I just pull them up until they feel right. :wink:
