peugeot 106 cold starting problem
tomtaylor
My Peugeot 106D (1996 and only 55,000 K) has a cold starting problem. I have checked glow plugs, battery and cold start system, which seem to be working ok. Once started and run for 5 minutes it will run smoothly (even after stopping the engine and starting again after 3 hours or more). A garage has told me that a likely cause is low compression and possibly liner problems - expensive!! However, today I have noticed a small fuel leak from around the stop solanoid. Is this likely to be the cause of my starting problem? I have attempted to prime system by using bulb to no avail. Any advice would be appreciated before I go to an expensive garage for repair.
silverline
- x 1055
