Xantia TD - how do I remove the engine fusebox?
ecohouse1
- x 3
Hi, I am looking to get at the wiring below the fusebox in the engine bay on my Xant TD mk2 and cant see any obvious way to get into it. Is there a knack to unclipping it or is it bolted in? Many thanks, Cheers, Alan
citroenxm
- Fallen Hero
- x 70
Re: Xantia TD - how do I remove the engine fusebox?
Its a bit of a dismantle job, you need to remove the two Purple relays up against the inner wing inside the fusebox house pop up the relay holders, the relay sockets twist out, and then IM SURE If I have remembered correctly the fuse box slides off the two prongs towards the inner wing...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
ecohouse1
- x 3
Thanks for that. I will have a go. Cheers
