Xantia AL4 interchangeability
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Is the AL4 that is fitted on a Xantia interchangeable with the AL4 of a Xsara ? Citroen C4 or C5 interchangeability
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
citroenxm
Fallen Hero
x 70
Re: Xantia AL4 interchangeability
Unread post by citroenxm »
Yes most likely, cannot see why not, as long as the bell house to block bolt patten is the same, OR unless you are taking it from an identical engine... so if the Xsara or C4 is a 2.0 16v petrol too then I cant see an issue.
A very sad...
1994 XM 2.1 d auto
Mandrake
x 697
Unread post by Mandrake »
Check that the final drive ratios are the same...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
