Seeing how utterly useless the Forum Search is, I decided I had to make a post on it.... Its either utterly rubbish or I cant use it, anyway..
Ive also asked on CCC facebook page, but basicly Im facing a C5 with a dead suspension pump. So what I need to know is, how or what sort of a job is it to swap the suspension pump? Is it easy, hard? Messy?
C5 Suspension Pump Mark 1
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 5672
Re: C5 Suspension Pump Mark 1
This any use Paul:
C5 Suspension Pump Faults
Best to use the Google Advanced Search for digging deep into the forum.
- x 1055
Its not a hard job but it can be a bit messy. You need to remove the wheel arch liner & the headlamp for access. Nearly every one I have changed has needed pressure to be applied to the system to get it to lift afterwards, a normal cooling system pressure tester kit does this no problem & half a bar is plenty.
citroenxm
- Fallen Hero
- x 70
Thanks guys thats brill.
ill see how many fuses it pops but we are prepared to swap it out...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
