It would not move using the buttons. The owner was told to buy a new "Pump" by a Sussex based garage that previously said the same car needed a new "turbocharger".
The previous turbocharger fault was cleared by changing the oil.
The history of this suspension fault was that the car had a new tyre fitted and also suffered a flat battery when the lights were left on.
The battery has since been replaced.
I tried to clear faults by disconnecting and reconnecting the battery following procedures mentioned elsewhere on this forum.
I bought a copy of Lexia 3 7.76. It works on this car and on my own C5 Mk 1.
I found the fault log full. 60 in total. I read them and cleared them. Many of the faults were low voltage at various ECUs that made sense from the flat battery issue.
The radio and multifunction display have faults that return. The injectors have faults that return. I consider that these faults are of a minor nature.
The suspension had faults.
Permanent Fault - Body Height Sensor Front
Permanent fault - Body Height Sensor Rear
Temporary Fault - Steering Wheel angle sensor no value received
Remote fault - Temporary fault - No communication with built in systems interface.
I did notice faults
D305 No communication with the steering wheel angle sensor.
D105 Steering Wheel rotational speed information no signal.
These were all cleared.
Using the Actuator Test functions of the Lexia.
The Pump runs for a short period but the vehicle does not rise.
Now when I push the rise up button by the gear stick the pump runs for just under 5 seconds but does not rise.
I would appreciate some input from my fellow forum members to try and diagnose the actual fault.
I am not experienced with the Lexia but have good computer and mechanical knowledge and I am an Electrical Controls and automation engineer by profession (non automotive).
The car is right on the bump stops so will not drive.
