citroen synergie driver side door mirror replacement
shahidocean
x 6
Unread post by shahidocean »
guys,
I tried to fit the mirror today and it looks like I have to take the door panel off. It looks a bit fiddly does anybody know how to get it off,
any pics diagrams etc would be greatly appreciated
2001 citroen synergie 2.0 hdi slx
Richard_C
(Donor 2026)
x 224
Re: citroen synergie driver side door mirror replacement
Unread post by Richard_C »
This from distant and possibly flawed memory, best I can do:
At the top end, you push the lock button down to make room to lift the door panel over when you finally get there. Or do you pull the plastic straight up leaving just a metal rod? Should be obvious when you come to it.
I think you pop the window switch panel up, screwdriver carefully under the end, and disconnect the wires.
There are screws on the armrest which comes off, also one or two around the speaker grille. There may be a screw behind the door release lever as well and you sort of wiggle the trim surround off but leave the lever mechanism in place.
With the speaker grille off you can unhook the door pocket (there may be a screw near the back of the pocket). Getting that off reveals more screws behind, maybe you have to take the speaker itself off. Its 10 years or so since I did it but I have a vague memory of lots of bits to dismantle.
With most of that stuff out of the way, you lever the panel off from the bottom and up each edge, poppers to unpop, then lift it off vertically. Maybe I had to take the plastic trim off the rear edge of the window frame, or at least ease it out.
Hopefully someone with more recent experience or a picture will reply soon. I don't remember it being particularly difficult, just tedious.
Richard_C
shahidocean
x 6
i've just replaced it now didn't see the arm rest screws till the end , pretty fiddly but mirror is fitted and i don't have any spare screws so job well done ... thanks.
