Bergen, Norway says hi !
HansNOR
x 7
Unread post by HansNOR »
Hi there. I'm Hans from Bergen in western Norway and at the moment i'm looking out the window and see what I've seen some 280 days this year ...... rain .
I have a liking for Citroen .. preferably with hydraulics and some quirky traits .. but i must admit its been a few years since i last laid on my back in the rain in some random parking lot replacing
hydraulics :) I'm quite certain I have said never again to Citroen with LHM ... but never the less, now I am back to it .
The car itself and probably more about me will be told in a blog on this forum. Think that is a good feature as it serves as a "notebook".
wish me luck as I'm allready battling the green leak ... ;)
x 8181
Re: Bergen, Norway says hi !
Welcome from a fellow Activa owner/lover :D
I've posted in your other thread on the subject of the leaking electrovalve, I hope it'll be useful...
HansNOR
x 7
Thank you Jim, i will look at that right away. I've studied many of your how to threads. i really appriciate those :)
btw. Is it possible to change my nick ? for some reason i did not register with my real name like u use to :)
x 8181
Pleased you're finding the stuff on the forum useful :D
Turbofeber wrote: btw. Is it possible to change my nick ? for some reason i did not register with my real name like u use to :)
Yes it is, just tell the admins what you'd like it changed to and they can do the necessary :)
x 1980
Unread post by Stickyfinger »
This may help you visualise what you have there......
x 8181
The Stickyfinger tin-opener strikes again!!!!
x 1980
The best way Jim......stuff dropping the subframe !
x 8181
Stickyfinger wrote:The best way Jim......stuff dropping the subframe !
I quite agree Alasdair!
superloopy
x 19
Unread post by superloopy »
Alisdair... have you got a template for those cuts needed? Thinking about swapping hoses on the rear ram and might come in useful.
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
x 1980
Hi Mike....Happy New Year mate.
I never did put a ruler on it :)....but I have these which should help.
Maybe a little small but you can get the tools/hand in there, I may very well enlarge (width) it at some time if I need to and just go to a scrap yard/make a new cover.
The S2 floor is redesigned btw
xantos
x 10
Unread post by xantos »
I saw this once and I totally forgot about this. BRILLIANT! Really a PITA to get some work done without removing the subframe. Must remember to make this mod in my V6. Btw. what is that yellow stuff on the hydractive block? Grease?
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
x 1980
Electrical contact water proofing spray wax, I am testing it to see how it does in preventing Aluminium corrosion at the electro-valve joint
HansNOR
x 7
very nice info again stickyfinger - ill try to throw them pics in my blogthread .
x 1980
np, best to copy/save them over as I may at some stage change host and you would then loose the link.
HansNOR
x 7
ive saved them on my computer - so if they go poof here ill upload them
