Hi All,
Today, I had an interesting trip in the Xantia.
As the car was warming up, both the stop and temp light came on the temp on gauge was at max, but it went off after 10 seconds and settled down to run at normal operating temp.
Could the thermostat be sticking or is the temperature sender faulty after all the shenanigans with the coolant.
Kenny
Stop and temp light
KennyW
- x 163
Stop and temp light
C3 1.4 petrol (SWMBO)
lexi
- x 134
Re: Stop and temp light
Easiest one first is coolant sensor, and the more likely culprit. Then the stat, which is a possible.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
KennyW
- x 163
Is the coolant sensor located near to the thermostat housing ?
Kenny
Kenny
lexi
- x 134
I haven't been in at mine yet on 110 hdi, but it is on that side of block around the battery area.
I put a new Calorstat in easy enough. I think those TCS are normally around a tenner.
The Vel Satis did the Stop and overheating thing about 8 months ago. You could see the temp gauge going up and down like a yoyo.
I bought both the TCS and the stat. It was the TCS. £8 for a Delphi one on Ebay.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
KennyW
- x 163
Confirmed the sensor is in the thermostat housing, will get a sensor next year!
Kenny
Kenny
