Another XANTIA problem
ash
Flipping heck, as well as cold starting problem and faulty speedo. Both my door locks are now faulty. When I try and use the key, the key just rolls in the barrel. Do I need new locks or can I take another course of action ?
RichG
If the key is not fully inserted into the lock then the barrel will rotate 360 degrees without doing anything (I use this as a way to oil the locks!).
Check that there is nothing stopping the key entering the locks fully or try a different key. It is strange that it has suddenly happened on both locks as this would point to the key being faulty or damaged. Does the key open the boot OK?
Richard
Richard
lhm_leak
AndersDK
