Hi folks. Just finished cambelt/ tensioners/ water pump/ cam and crank seals. First one on this car. Engine was pinned, followed Haynes and threads here. Starts fine, revs fine, only drove literally round the block. But...she sounds more clattery. So am wondering if it's normal to check pump timing? Or should I pull her apart again, could I be a tooth out?
Thanks!
New cambelt...engine clatter...check pump timing?
Jaf
- x 42
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
KennyW
- x 163
Re: New cambelt...engine clatter...check pump timing?
Jaf,
On the TD's it is very easy to get 1 tooth out hence the noise. It's a case of doing all over again. I had this prolem before and started again and got it right no noise or clatter.
Kenny
Kenny
C3 1.4 petrol (SWMBO)
Jaf
- x 42
Balls! Thanks Kenny, will do it all over again.
Jaf
- x 42
Just to say...took her apart. Checked and yes it was a tooth out! Don't know how, checked and re-checked. Anyway sounds fine now.
Got to find the fuel leak and then off for Spanish MOT.
Thanks again.
Thanks again.
Jaf
- x 42
Oh yeah meant to say...don't start the engine without the crank pulley on!!! The belt tried to come off in less than 30 secs!!!
