V6 ES9J4 Locking pins
xantos
- x 10
Shortly I am about to change the cambelt on my Xantia V6. Can someone tell me the dimension (diameters) of the locking pins? As far as I know two have different diameters through the length...
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet
C4 Exclusive 2.0 HDi (gear shifting b****!)
- x 8457
Re: V6 ES9J4 Locking pins
I can as soon as I'm home Xantos as I have an ES9J4 on the stand right now with cams locked..
I think they're 6mm at a guess..
- x 1481
- x 8457
xantos
- x 10
Thanks!
So the locking pins aren't designed like the two bottom ones on the picture (different in diameters)?
- x 8457
No, like the two top ones but in the shape of a 'T'xantos wrote: So the locking pins aren't designed like the two bottom ones on the picture (different in diameters)?
Stempy
I did my C5 V6 without any special tools, just found the right size bolts and improvised the rest.
Lexia ponce
Lexia ponce
xantos
- x 10
Yes I did that also on my 1.9TD, but when I did a bit of research for V6 engine I came across the pins with different diameter through the length... So M8 bolt should do the trickStempy wrote:I did my C5 V6 without any special tools, just found the right size bolts and improvised the rest.
