Hi folks, great Forum.
I need to pick some brains, I have a 2006 Citroen C5 1.6 HDi 110 (Non-FAP, I think??) Design. Bought from an Independent dealer a short time ago and has a multitude of issues. Initially brakes were hopeless, and engine wasn't pulling as I thought it should. After going back several times and getting nowhere (Nowt wrong with, thats just old Citroen's mate!!!), I made a claim through the Credit Card company. To cut along story short (PM if you want the full story), brakes sorted at their cost, but still left with engine issues.
Done the usual, good service, check pipes etc Also DMF and Clutch changed, MAF replaced.
Left with the following:
Turbo blades damaged, but no blue smoke or significant end float. Possibly damaged by flaking insulating tape that was used in place of proper rubber sleeve. Would a CHRA change be enough, or replace entire Turbo?
Double throttle body (air doser) unit, only one has a electrical connector in, the one nearest the timing belt end of engine. The other (nearer the turbo) is unplugged and I can't find the plug/connector for it anywhere. Any ideas where it should be or go? It has the 9HY engine.
Have photos but not sure how to add them to the post
Ran the Lexia on it and only issue thrown up was glow plugs?
Any thoughts or pointers anyone?
Thanks in advance
Citroen C5 issues
citroenxm
- Fallen Hero
- x 70
Re: Citroen C5 issues
Hi Folk.... (Didnt catch your name..
Ok, a CHARA Cartridge is as good as new for a fraction of the price!
Ive just done one on a 55 plate 1.6 hdi, its all in the blog for the car... urrrm here.. http://www.frenchcarforum.co.uk/forum/v ... 1&start=30
Its NOT a hard job to do at all. Ive done a C4 90bhp and a C5 110 now...
I changed mine as I also had some fins broke, but you can see that if you look through the whole blog.. the turbo still physically worked, but as you can see it also leaked soot too!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
mm4015
Thanks citroenxm, I'll have a look at the blog, should give me some good info and pointers.
In general I like the car, Its a great drive just lacking ooomph and been missing some mechanical kindness in the past. My other half has a 1.6 hdi (92) Pic that I'm using as my benchmark, so reckoning the C5 should be quicker.
I'll look at doing that with the turbo as I'm reasonably handy with the spanners, my fiancé probably wouldn't agree though lol.
Thanks again
And Merry Xmas
Mark
Thanks again
And Merry Xmas
Mark
citroenxm
- Fallen Hero
- x 70
My 1.6 16v 110 goes rather well.. Im certain all C5s were 110s with the 1.6 ... The other issue of there is still no boost is the Vacuum electroc valve might not be working... When you start the engine the vaccuum should build up and pull down and close the wastegate.. If you look under the oil feed pipe you can see the wastegate lever, with the engine running it should be pulled right down into the vac canister unit..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
mm4015
Yeah I've driven a few cars with variations of that engine, they're great for their size and economy. Throttle response on my fiancés Picasso 1.6 hdi (92) is excellent, which why I was disappointed in my C5 which is meant to have an extra 20 ponies. They're both same age, and similar mileage. I'll check the vac valve, had something similar go years ago go on my Pug 406 2.0 HDi. I'll do the CHRA and oil lines as looked like an easy job going by your blog, which is really good. Cracking deal you got.
Here's a link to a post on the C5 forum, it's got pics : http://www.citroen-owners-club.co.uk/ci ... entry87498
Need to decode the VIN so I know what it left the factory with, tried the decoders on Google but they're crap, know of any that are accurate?
Thanks again for your help and info.
Mark
Mark
citroenxm
- Fallen Hero
- x 70
With the VIN we can get the full info from the citroen service web site.. im a member there .
Fit a new oil feed pipe to the turbo . While the turbo is off remove the exhaust bracket nuts as the oil feed pipe is secured behind it. Theres no need to remove the bottom pipe connection as the flexi connection lets the cat/dpf come forward enough to get at the banjo ..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
lexi
- x 134
Is there any evidence that these Cartridges are able to do the big miles?
Is the quality there?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citroenxm
- Fallen Hero
- x 70
Yea id say so.. they look a bit good... but saying that.. looks arent everything..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
mm4015
Cool I'll PM you the VIN if that's ok. Ordered the parts up, just need to wait for them to arrive.citroenxm wrote:With the VIN we can get the full info from the citroen service web site.. im a member there .
Cheers
mm4015
Thanks for the vin info Paul, answers a few questions.
I'll keep you posted on progress
Cheers
Mark
Cheers
Mark
