POSITIVE BATTERY CABLE?
HDI
x 7
Unread post by HDI »
Does anyone know if the positive battery cable on a P reg Xantia l is the same as an HDI? Just thinking, the cable on my HDI has a broken clamp, so if the TD cable is the same I can salvage it off my scrapper! It looks very similar from what is visible without dismantling.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 1240
Re: POSITIVE BATTERY CABLE?
Unread post by Peter.N. »
I would think its quite likely but I think the only way you are going to find out is to take it off, or at least find the other end and measure it.
HDI
x 7
If it isn't part of the main loom I'll pull it out and see.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
superloopy
x 19
Unread post by superloopy »
Cant you get the lengths of each off service.citroen?
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
wurlycorner
x 271
Unread post by wurlycorner »
Just need to check the part numbers on service.citroen, to see if they match, surely?
Iain
CX DTR T2 Safari (silver)
superloopy
x 19
Great minds ....
Mike
