Have changed the MAF sensor on the van and now all is well.
Now the cat seems to be rattling around and was wondering if it was possible to de cat it ?
Dispatch van 2:0hdi 2003
De Cat
pikecrazy
De Cat
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim
Bick
- x 44
Re: De Cat
Yes you should be able to purchase a decat piece for the exhaust. However, why, cats are not that expensive now and they dont cause problems like particulate filters. May as well replace it and save the world from a small amount of nasty gasses.
- x 1988
Re: De Cat
Does the car not need a remap when decat has been done ? and would that not cost more than a new cat/2nd hand ?
Bick
- x 44
Re: De Cat
No remap needed.Stickyfinger wrote:Does the car not need a remap when decat has been done ? and would that not cost more than a new cat/2nd hand ?
lexi
- x 134
Re: De Cat
Can't disagree, diesels are horrible on fumes. Does the cat do any good in that respect though?May as well replace it and save the world from a small amount of nasty gasses.
I reckon they don't work on short or town journeys. Also the aftermarket cats are not as good.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Bick
- x 44
Re: De Cat
a Cat will not work correctly unless hot so in the winter on short journeys or when stuck in traffic in town they will not work as well. When you say fumes it depends what you mean, smoke no because that is small particles of soot. Buy a cat does reduce the Nitric oxide and carbon monoxide both which are very nasty gases.
A good aftermarket cat will be fine try GSF.
pikecrazy
Re: De Cat
Not at £415.20Bick wrote: A good aftermarket cat will be fine try GSF.
isisalar
- x 3
Re: De Cat
I was told that it's an MOT fail if the cat is removed. Try Jaystock for a new one they're generally ridiculously cheap, complete system for my HDI Xantia was around £130 if I remember right, and free delivery.
http://www.frenchcarforum.co.uk/forum/v ... 15&t=47182
J reg 1.9d auto BX first Citroen
M reg 1.9d auto Xantia lx
N reg 1.9 td Xantia VSX Estate
T reg 2.0HDI Xantia Exclusive Estate Present car
M reg 106 diesel red
L reg 106 diesel white
02 Saxo 1.1i desire wife's present car(sadly now very ill cambelt gone- Doh)
Bick
- x 44
Re: De Cat
Holly sh1t i did not realise they were that expensive - for my Citroen Relay 2.0hdi its less than £200. Try ebay or Carsparespikecrazy wrote:Not at £415.20Bick wrote: A good aftermarket cat will be fine try GSF.![]()
