This is my first post and I'm new to the forum so please understand any possible silly question I'm going to post..
Some background information:
Everything started when - while replacing the rear brakes' pads of my Citroen C5-X7 (year 2008) - I unintentionally pulled the manual parking break leverage and one of the two brakes' cable reteired within the EPB box.
For this reason I was not able to replace that brake's pad and had to open-up the EPB box in order to unblock/free the cable.
After that I close back and seal the EPB box and reinstall it, but when I tried to set the auto-parking functionality in the car menu, the car display showed me a lot of errors (i.e EPB error, anti-reverse error, etc..).
I went to the Citroen Assistance and they tried to clear the error code and re-calibrate the brakes but with no success.. Now, when I try to activate the EPB manually an intermittent sound can be heared from the EPB box as if the internal EPB motor was trying to pull the brakes cables but it didn't grip (attach an inner photo of the EPB).
The fact is that replacing with a new EPB costs about 1.000 € (without labour cost)!!
So I bought the DIAGBOX and yesterday I made a first check. Below the list of the errors the tool reported:
- C1559 System locked : Electric motor, cables or calipers (type: "Temporary")
- C1554 Electric motor temperature sensor fault : Coherence (type: "Temporary")
- C155E Mechanical release of the Electric Parking Brake detected fault (type: "Permanent")
- C1550 Brake cable faults (type: "Permanent")
- C155A Electrically-controlled parking brake not calibrated : Travel-effort pattern (type: "Permanent")
I'm wondering if some of the "temporary" errors may be solved by software/configuration or calibration and - for the "permanent" ones - if there are some possibility to solve them by opening-up the EPB box again and set the cables in the right "release" position (if there is any)..
I'm terrified if I have to buy a new EPB kit...!!
Please HELP MEEEE!
