Hi again! I have a xantia 1.6i 1993 without a keypad code! Its ecu is iaw 8p.13. What will happen if i put an ecu (same model) from a car that had a keypad immobiliser? Will the car work streight on with the new ecu or will be blocked from starting the car?
Thank you very much
Panos
Xantia xu5jp 1993 ecu swap
- x 1342
Re: Xantia xu5jp 1993 ecu swap
It would be locked. But don't even try it until you know for sure that the ECUs have compatible pin-outs, or you might destroy the ECU.
tioklou
Thank very much for your answer. I bought one from a same car (xantia 1.6 xu5jp engine,ecu model:iaw 8p.13) in order to remap it and keep mine in stock if anything goes wrong. but i dont know the details of the car the ecu come with(immo keypad etc).when i receive it i will post the numbers from mine and the new one in order to give me some more details.
tioklou
my ecu code numbers are: IAW 8P.13
16240.014
9619467680
the new ecu is: IAW 8P.13
16240.124
9621477380
Is something that i must worry me about about these differences? what is your opinions?
16240.014
9619467680
16240.124
9621477380
