citroen relay 2.2 03 plate
devineonline
hi i am new to the forum hoping someone can help me i have got a citroen relay 1800 2.2 diesel hdi it is x forces it has done 23000 miles it will rev ok in neutral and will go right up to 40 mph no problem but soon as i hit 40 it stops dead at a steadey 40 i think it might have a speed regulater on it has anyone got any idea how i tell and if i can remove it thanks
- x 1044
Re: citroen relay 2.2 03 plate
Any warning lights coming on ? If it has been speed limited it's normally done by altering the ECU software. Its a strange speed to set a limiter to, the lowest one I have ever known is 56 mph.
At 40 mph it wouldn't even be safe to use the van on a motorway.
devineonline
hi no warning lights had to drive it at 40 from grantham to merseyside but it spent its life on a army base the engine sounds smooth i am lost not sure if it is limiter thanks
devineonline
hi i am after some advice please i have been looking for a new body for my relay van but i have viewed 3 56 reg vans and all 3 have not had good sills so i have decided to break it instead. it is off army base and has done 23000 miles only. if i take the engine and box out to sell do i need to take the ecu out with it because i think the ecu might be faulty the engine sounds like new.it shows no faults revs great in neutral flies up to 40mph as i have said before any advice please
- x 1044
ECU is not required, whoever is fitting the engine can use their own ECU.
devineonline
thanks much appreciated
devineonline
hi i am after some more information on citroen relay 2.2 hdi 03 reg please i have been offered a 2.8 van is it much trouble if i put a 2.2 engine in it or is the set up different thanks
