Picasso 2.0 hdi 2004 DW10Td coolant flange/housing
bamba
Unread post by bamba »
As the title , i have a small coolant leak around the plastic thermostat /switch housing on the end of the cylinder head . Leaking from both the joint to the head an between the 2 halves that bolt together (note not leaking from the top of the stat housing top)
Can the main body of this housing be separated, there is about half a dozen small bolts , is it a O ring or sealant?
Is the complete housing available new anywhere ?
Cant seam to find it for the DW10td engine, can see a few similar items on ebay , but not for mine
Sent from my SM-G900F using Tapatalk
