Xantia Alarm
momag46
x 78
Xantia Alarm
Unread post by momag46 »
Hi all
My V6 Series 2 Xantia alarm has started going off BUT:
Only the alarm is going, the indicators do not flash :?
It does not stop when unlocked :cry:
The 're-set' system does not cancel it :cry:
I can start the car and drive away and it still keeps going :oops:
It keeps going for up to 5 minutes :!:
I can lock it with the key, no problems - but - it's too easy to forget and use the keyfob.
The car has been checked with a Lexia at Barry Annells but no faults were recorded.
Any ideas chaps [-o<
Maurice
1999 V6 Xantia
chinkostu
x 30
Re: Xantia Alarm
Unread post by chinkostu »
If you unlock and relock does it stop?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
momag46
x 78
Re: Xantia Alarm
NO
It only stops when it want to!
Unlock, relock, start engine, stop engine, drive car, only time seems to stop it
1999 V6 Xantia
elma
x 287
Re: Xantia Alarm
Unread post by elma »
I'd be baffled but would start by checking the battery then looking to try a different central locking ecu (as I believe it is responsible for the alarm.)
momag46
x 78
Re: Xantia Alarm
Battery okay, fully charged and no problems with starting etc.
Maurice
1999 V6 Xantia
momag46
x 78
Re: Xantia Alarm
Got nowhere with this - been using the key in the lock (remember how to do that?)
Can the Lexia pick up if a sensor is to blame and if so, which one???
Maurice
1999 V6 Xantia
x 1438
Re: Xantia Alarm
Unread post by xantia_v6 »
On a Mk2 Xantia, I believe that the alarm ECU remembers the most recent trigger causes, and these can be read by a Lexia.
momag46
x 78
Re: Xantia Alarm
Thanks for that - I'll have to have a work with Barry Annells.
Maurice
1999 V6 Xantia
citroenxm
Fallen Hero
x 70
Re: Xantia Alarm
Unread post by citroenxm »
You dont actually say if you use the Remote fob to unlock the car... this gives an ecu reset each time.. unlocking a car with the key in the door does not reset.. you can also reset by disconnecting the battery... leave a moment.. locate your alarm cancel button on the dash.. a sort of loud speaker with a cross through it.. not the rear window cancel button.. that has an up downn arrow on it with a cross and is on the same side... re connect the battery then press and hold the alarm cancel button and switch on the ignition.. the indicators should rapid flash and system reset. If you lock your car with the key and not the fob this also wont arm the alarm..
A very sad...
1994 XM 2.1 d auto
chinkostu
x 30
Re: Xantia Alarm
Maybe a dodgy connection to the alarm itself? I noticed on cold days my siren will sound almost like it thinks its been disconnected
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 8294
Re: Xantia Alarm
I believe the siren has its own battery backup.. After all these years it could be this that's failing...
Siren is not easy to get to (for obvious reasons) and it's a bumper off job to get at it...
momag46
x 78
Re: Xantia Alarm
Thanks again
I'm using the key so as not to set the alarm. When I use the 'fab' to lock the car the alarm is liable to go off but ONLY the alarm, the lights/indicators are not activated.
When the alarm is triggered I cannot reset it and it sometimes keeps on for 5-10 minutes; I can start the car and drive away (you get some funny looks :rofl2: )
By using the key to lock the car the alarm is not set therefore okay. I'm now only carrying the key 'cos it's so easy to go into auto-pilot and use the fob.
I've not gone through the battery disconnect route 'cos I also thought the alarm had its own battery.
When Barry's son Pete connected up the Lexia, no faults were recorded.
The car is only used occasionally this time of year so the problem is not to much of an issue yet.
Maurice
1999 V6 Xantia
chinkostu
x 30
Re: Xantia Alarm
Mine did that once, randomly started going off 20 minutes into a journey!
Iirc you can pull the fuse for the alarm and still have locking, atleast on the S1
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
