Dispatch Turbo
pikecrazy
Dispatch Turbo
Unread post by pikecrazy »
Hi Guys......... Been a while :-D
Seem to have a bit of lag on the turbo whilst accelerating ie a 3/4 seconds then it picks up fine ?
2003 HDI Dispatch
Any ideas ??
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
Bick
x 44
Re: Dispatch Turbo
Unread post by Bick »
What engine 2.0hdi?
pikecrazy
Re: Dispatch Turbo
Yes sorry 2.0 hdi runs fine in every respect just takes a while to pick up revs if you floor it,
Bick
x 44
Re: Dispatch Turbo
You need to get a diag done really or you could be replacing things that you dont need to, so that is your first port of call. However the maf sensors do play up and cause your symptoms, i would try disconnecting it and see how it runs then.
x 3299
Re: Dispatch Turbo
I agree with Bick, in that you do need to get the van diagnosed, otherwise you will just waste money chasing the fault down. Fortunately there are members with Lexia kit willing to help other members;
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178
x 1240
Re: Dispatch Turbo
Unread post by Peter.N. »
You could try cleaning the maf with some carburettor cleaner only don't poke it, very delicate.
pikecrazy
Re: Dispatch Turbo
No fault codes too show have just put a new air filter on to see if it helps.
(need some cleaner to clean gauze filter and maf)
Disconected sensor but no difference.
Out in a bit so i'll see how it is.
x 3299
Re: Dispatch Turbo
If you are using a generic code reader on a Citroen or Peugeot it probably won't work (especially on older cars) as the PSA group use their own software. A Lexia can (as it is a clone of the PSA system) read them though, which is why I added the link in my previous post.
RPWC
x 21
Re: Dispatch Turbo
Unread post by RPWC »
pikecrazy wrote:No fault codes too show have just put a new air filter on to see if it helps.
use some IPA in a jar for MAF,Isopropyl alcohol, use the same for the filter,you can buy a litre of it from Maplin stores, for around 5-10 quid.
Cheers Rich :wink:
pikecrazy
Re: Dispatch Turbo
Thanks for all the hints just need the Lexia fixing now :(
