'07 C5 rear discs - same as X7?
Johnno
(Donor 2022)
Unread post by Johnno »
Hi, I'm scrapping my '07 estate (sniff) and the rear discs have effectively done zero miles since replacement. Can someone tell me if these discs are the same as on a '59 saloon??
Ta, John.
John
'59 C5 2.2 173 VTX+ saloon, Jaguar 3.8 MkII 1961
RIP - '07 C5 2.2 173 VTX+ Estate
DHallworth
x 167
Re: '07 C5 rear discs - same as X7?
Unread post by DHallworth »
Hi John,
PM me both chassis numbers and I can check for you :)
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
shame..
what happened to it Johnno?
John
chinkostu
x 30
Unread post by chinkostu »
if the 2007 one is a late mk2 then no unfortunately, the x7 has a completely different rear brake arrangement.
if they're both X7's then yes
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
Johnno
(Donor 2022)
Thanks for the replies guys. It's a MkII model, so presumably not compatible. It's not a big deal, just seems a shame to throw more money away.
As to what happened to it? Nothing major by itself, but it needs work to bring it up to acceptable standard and I don't have the time to do it. It's not worth paying someone else (I've already spent a significant amount of fruitless money chasing a rough running / stalling problem, which I'm now 99.9% sure is down to the HP fuel filter - doh!). The engine / transmission are excellent - even better, I think, than in the younger model I have. The off-side rear took a clout from a turning lorry a while back, the tailgate window doesn't open, there's a leak in the tailgate seal, the aircon needs re-gassing at least, the hydractive system has stopped working, it needs work for an MOT, including tyres all-round, the steering system has always been less than smooth and is getting worse - see where I'm going with this? There's the de-pollution fault and then tax and insurance are due.
All in all, I feel I ought to make the effort, but sometimes you just have to cut your losses!
I'll really miss the space, comfort and load-carrying (should have it's own postcode!) and I even rather like the looks - certainly better than the saloon.
John.
John
