Hey guys
Any ideas? It had the injectors cleaned at Citroen main dealer one week ago, and smoke a bit less, but i still think its to much. It started when the weather did go from 20 degree C to 8-10 degree C. Also nr 1 injector was leaking at that time nr 2 did a little, but after i tightent them they dont leak anymore. I did tighten them in the same periode as the weather got cooler.
About the shaking, it helped a little with the tighten injectors when its warm, but it still Shakes.
It starts great, no smoke when warm and has to stand still for 5-6 to produce smoke at start up. Runs great, no splutter or turbo Lack.
Help
HDi smoking start and idle shake
Re: HDi smoking start and idle shake
Think you had more luck on the Berlingo forum lol
