C5 MK2 heater blowing cold on passenger
SageDesign
- New User
2008 MK2 C5 Exclusive: passenger side of heater always cold. Driver side works OK. Apparently NOT the control motors behind the glove box.
- x 2008
Re: C5 MK2 heater blowing cold on passenger
Apparently NOT the control motors behind the glove box. ? Why not ?
Normally it is not the motors its the gears on them
citroenxm
- Fallen Hero
- x 70
It wont be the motors them selfs but it WILL be the Flaps that direct the air flow, and useually the teeth IN the heater box itself...
Passenger heater motor can be accessed after removing the glove box, if you remove the motor you should find the motor will respond to heat change setings, but the flap control will either be stuck or the mating cog may be chewed...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
SageDesign
- New User
The motor responds to heat setting changes: the cog does turn, and the mating cog does move: about 1/3 of a turn, so I presume that the air distribution flaps are stuck. I have ordered a Haynes manual, but do not know how helpful that might be. How difficult is it to get at the flaps? In the process of trying to diagnose the problem, I now have the cog & the mating cog out of sync!citroenxm wrote:It wont be the motors them selfs but it WILL be the Flaps that direct the air flow, and useually the teeth IN the heater box itself...
- x 2008
Was there not a method developed by the 405 guys regarding the flap controls/flaps ?....I cannot find the link atm.
- x 1482
Type "407 flap" (without the quotes) into the google search box beneath the header on this page. There are several useful hits.
