Knock Knock - Droplinks or wishbone bushes?
chinkostu
x 30
Unread post by chinkostu »
Got an irritating knock going over bumps in the Xantia now. sounds exactly like droplinks but they were replaced earlier in the year. getting under the wheel arch and wobbling stuff around doesn't bring much joy, there seems to be a smidge of play in the rear wishbone bush but no knocking noise when agitated, and the droplinks don't knock if i grab them and rattle them about. however if i grab the roof and rock the car you can hear it knocking like a...well you know the euphanism :rofl2:
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1480
Re: Knock Knock - Droplinks or wishbone bushes?
Drop links.....cheap ones are paaaaaaants! Fit lemforder, or get a pair of Myele heavy duty ones.
electronmirror
x 31
Unread post by electronmirror »
As already noted, cheapo droplinks can be shot in a matter of months. Could it be lower ball joint?
I had similar noises which turned out to be the lower ball joint and it was fun replacing that ! Couldn't spot it until I had both front wheels off the ground with axle stands under the front jacking points.
Ted
2010 C5 2.0 diesel(163) Exclusive Tourer (133,509miles)
1999 Xantia Exclusive Estate 110 Hdi Mauritius Blue with self peeling lacquer finish (276,174miles)
1991 XM Prestige 2.0 Auto(157,000 miles) gone but not forgotten
chinkostu
x 30
Ah so it could well be the droplinks. Bit of a bugger but at least they'll be easy to swap out given they're fairly new. Strange that I cant feel the play as on a friends punto it had a noticeable knock when you grabbed the rod.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
x 1480
I've fitted cheap ones that knocked out of the box....
If you can hear it when rocking it, it's the drop links - ones on our Picasso were like that. I fitted the Mylele ones nearly 2 years ago, and still quiet.
dnsey
x 19
Unread post by dnsey »
Even with quite a loud knock, there's sometimes only just discernable play in the droplinks when they've been removed. You'd never feel it on the car.
c.morewood
x 55
Unread post by c.morewood »
Just a thought, check out the inner steering rods .. mine had quite a bit of play and I was on the point of buying new drop links as I discovered the track rod play.. made a lot of noise especially over potholes.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
red_dwarfers
x 58
Unread post by red_dwarfers »
Certainly with my particular Xantia, the drop link part numbers were the same as the Peugeot 106 and there were a few listings for genuine Peugeot 106 bagged ones on eBay going cheap!
Kev
'19 C4 Cactus 130 Flair
